good day gurus
ive set up a y6b with apm 2.6
flown it in stab mode
but when i switch it to alt hold is hear the motors are pulsating or oscilating but you cannot see it,
already done
thr_mid and it 350
thr_min 100
the two are set right now
now i havent touch the PIDs on altitude p, throtle p and throttle accell
im trying to understand whats written here http://diydrones.com/forum/topic/new?target=http%3A%2F%2Fdiydrones.com%2Fforum%2Fcategories%2Farducopter-2-x-multicopter%2FlistForCategory&categoryId=705844%3ACategory%3A362638
can some please explain.
tnx
i have solve the problem, reseting all parameters and re installing fw 3.2.1 was the solution
tried yesterday
tune via ch 6 alt_p, ins_mpu filter set to 20,
adjust thro_accel and rate
i have played around with this even the refresh rate of esc, i have chek logs for vibration and seems okay according to what ive read,
chek also for baro error but it seems ok
it also pulsate even if props are remove, you can hear them.sounding like pumping
Have you tried the auto tune feature?
https://www.youtube.com/watch?v=5pqdAOCkz00
Also they are going to pulsate as they are trying to maintain altitude right. If the wind blows then pressure is changing. Do you have a case over your sensor on the chip? Is there foam over it to reduce airflow?
