Alt Hold problems
I've was very happy with the lateste ACM code concerning AH.
Untill I switched to v48.
In AH mode the motors start pulsing alot and suddenly go up to a certain height, I think the border height between sonar and baro. When reached it starts descending fast, sometimes hitting the ground.
I reloaded the code several times and always performing a reset. Results were the same.
This morning I reverted to v43 because I knew that it work perfect.
I did the test and ..... damn, the same behaviour :-(
So I think I hit a HW problem. But which on???
I also CLI tested baro and sonar and all give postive results.
When I look at the logs I see that the sonar sometimes give a negative peak.This could be the pulsing motors.
Any suggestions?????
2011-10-16 10-08 23.log
