Alternative to Xbee?
Hi, i'll be using this on a heli, and i'd like to know if there are alternatives to the Xbee 2.4 and 900 modules. Problem is, my receiver is 2.4 (so that rules the 2.4 xbee out) and really doesn't like 900mhz anywhere near (which rules out the other option). Would that: http://www.sparkfun.com/products/155  be something to consider since it's 433mhz?
Thanks!
  • no, because these modules only support 9600Baud, which is too slow
    there are other modules that you can use
    but you can use 2.4Ghz Xbee and your 2.4Ghz RCsystem at the same time ;) (video would become a problem...)
