Altitude accuracy
Hi All,
I am running a bixler with the Arduplane 2.28 firmware. Everything works pretty well, but I have been seeing a few strange issues with the reported altitude of the plane. The spot where I launch is 10m above sea level, but when I reload the home coords into the GCS after booting up the plane, I get anywhere from 8 - 22m reported.
Then when flying, I will set the altitude of the plane to 100m relative, but the altitude reported by the plane in the GCS is usually around 120m-140m, which is usually more than the home alt + 100m. The real altitude of the plane would be possibly around 70-80m based on my observations.
What kind of things affect the altitude reading? I know it is a combination of Barometer and GPS, but I'm not sure how exactly the interaction works. The interior of the plane can get quite warm from the ESC,  would this fool the barometer into thinking it is higher up?
Any insights would be appreciated.
Regards
James
  • I have had the same problem and discovered the altitude varies depending on the speed of the aircraft. Basically i was pressurising the inside of the plane. I solved the problem by connecting the pressure sensor to the static line of the pitot
    I'm not an arduplane expert (I deal more with arducopter) but I don't believe that GPS is used at all for altitude because it can be very inaccurate at times.  I think it completely relies on the barometer.
    The barometer has temperature compensation in the code but not sure really if that would cause issues.
    The barometer on the APM2 is far better by the way.
