Altitude hold climbs suddenly??? AC 3.2
Flying in position hold today and I was noticing big fluctuations in my altitude hold. Sometimes the quad would randomly jump up 50Ft. Looking at the logs alt and dalt line up pretty well. But throttle in and throttle out doesn't seem in sync. When I have throttle in stuck at 50% sometimes I will get huge and wild fluctuations in throttle out. Can anyone offer some advice for tuning my altitude hold?
23.BIN
  • This log may even better demonstrate my issue. At around 4min if you log THRin and Dalt, you can see i'm dropping from 50% throttle down to about 25% throttle but the desired altitude is climbing for some reason. Whats going on here?
    21.BIN
    • you have very bad vibrations on accel Z. the climb happens at the same time as the vibes get really bad.
      Sort out your vibrations and or check your flight controller is mounted properly, if it is mounted to reduce vibrations make sure nothing is hitting or clamping the flight controller such as a vibrating/clamped cable or something
      • Hrm thank you for pointing this out Stuart. My pixhawk is mounted on moongel and all the wires have some slack. Maybe I need to find another mounting method.
        • no worries. If its vibes I would look at that too. better to not have vibes in the first place than trying attenuate them
          • ya im going to check the balance of my props and motors tomorrow. Now I have a path to go down, thanks.
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
sam liked Jimmy Oliver's profile
Aug 25
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
