Analog RSSI from cheap 915MHz radios
I would like to build a stand-alone telemetry tracker based on the analog signal strength of the incoming signal. I plan on using a relatively large DISH antenna or 4 YAGIs, and 4 receivers .  The signal strengths would be tested against each other, and the antenna would be turned accordingly.  In order to do this, I need 4 or 5 inexpensive 915Mhz receivers that output analog RSSI data.
Does anyone know of such receivers, or know of a modification?
  • OpenUAS said:
    Si1000 based modem with SiK opensource software the 3DR "clones" see https://ardupilot.org/copter/docs/common-3dr-radio-advanced-configu...
    So you asked for analog RSSI, good on the Nice RFD900/868 there are I/O pins left else on those $20 cheap modem one has to solder a wire to an I/O pin on the Si1000. I recall in the source ther was "AT+P=x set power level pwm to x immediately".  https://www.instructables.com/id/Analog-Output-Convert-PWM-to-Voltage/. Make sure you disable dynamic TX power levels BTW.
    Have some 6 Xtend gathering dust,  they have analog RSSI pin, send me a PM you can have m for free.
    XBee's also have PWM RSSI out... Also there I have quite a bunch you can have.
    I would love this!  I tried to PM you but couldn't because I'm not your "friend".
    I would like to build a stand-alone telemetry tracker based on the analog signal strength of the incoming signal. I plan on using a relatively large…
  • Si1000 based modem with SiK opensource software the 3DR "clones" see https://ardupilot.org/copter/docs/common-3dr-radio-advanced-configu...
    SiK Radio — Advanced Configuration — Copter documentation
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13, 2022
