Another "no throttle" problem
Hi all,
I'm having a similar problem to what has been posted before, and tried the solutions posted (as far as I can tell) to no avail.  I'm running 2.6 on the blue shield with XY and Z IR sensors and pitot tube installed with a Spektrum DX6i Tx and running power off the ESC (no separate battery).  All controls, including throttle, work fine in manual mode.  When I flip to Stabilize, I get no motor action.  Other controls work fine and the IR responds as expected.  Here is the serial monitor log from that... you can see the ch3_in go up, but nothing happens:
###STABILIZE 1***
+++ASP:0,THH:0,RLL:7,PCH:-14,ch3_in:957,***
!!!LAT:40312635,LON:-83100942,SPD:0.0900000000,CRT:31.0000000000,ALT:297,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0466801834,TOW:0,***
+++ASP:0,THH:0,RLL:11,PCH:-13,ch3_in:1020,***
+++ASP:0,THH:3,RLL:11,PCH:-13,ch3_in:1116,***
+++ASP:0,THH:15,RLL:11,PCH:-13,ch3_in:1206,***
+++ASP:0,THH:27,RLL:13,PCH:-13,ch3_in:1305,***
+++ASP:0,THH:41,RLL:12,PCH:-14,ch3_in:1414,***
+++ASP:0,THH:54,RLL:12,PCH:-14,ch3_in:1523,***
+++ASP:0,THH:67,RLL:12,PCH:-14,ch3_in:1626,***
+++ASP:0,THH:81,RLL:11,PCH:-13,ch3_in:1733,***
+++ASP:0,THH:90,RLL:12,PCH:-12,ch3_in:1808,***
!!!LAT:40312631,LON:-83100943,SPD:0.0700000000,CRT:37.0000000000,ALT:299,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0670799970,TOW:0,***
+++ASP:0,THH:96,RLL:13,PCH:-13,ch3_in:1853,***
+++ASP:0,THH:95,RLL:12,PCH:-14,ch3_in:1852,***
+++ASP:0,THH:88,RLL:12,PCH:-14,ch3_in:1791,***
+++ASP:0,THH:74,RLL:11,PCH:-13,ch3_in:1683,***
+++ASP:0,THH:56,RLL:11,PCH:-13,ch3_in:1533,***
+++ASP:0,THH:31,RLL:13,PCH:-13,ch3_in:1337,***
+++ASP:0,THH:11,RLL:11,PCH:-13,ch3_in:1179,***
+++ASP:0,THH:0,RLL:13,PCH:-13,ch3_in:1085,***
+++ASP:0,THH:0,RLL:11,PCH:-13,ch3_in:1030,***
+++ASP:0,THH:0,RLL:13,PCH:-13,ch3_in:999,***
+++ASP:0,THH:0,RLL:12,PCH:-14,ch3_in:981,***
!!!LAT:40312629,LON:-83100943,SPD:0.1500000000,CRT:36.0000000000,ALT:300,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0736183166,TOW:0,***
+++ASP:0,THH:0,RLL:13,PCH:-13,ch3_in:970,***
+++ASP:0,THH:0,RLL:11,PCH:-13,ch3_in:964,***
+++ASP:0,THH:0,RLL:12,PCH:-14,ch3_in:959,***
+++ASP:0,THH:0,RLL:11,PCH:-13,ch3_in:959,***
###MANUAL 0***
Same thing in Fly-by-wire-B mode... ch3_in goes up, but no motor action:
###FLY BY WIRE B 2***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:960,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:959,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1041,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1208,***
!!!LAT:40312659,LON:-83100885,SPD:0.2700000047,CRT:14.0000000000,ALT:313,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0866400051,TOW:0,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1437,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1633,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1748,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1816,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1855,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1847,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1788,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1670,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1489,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1295,***
!!!LAT:40312659,LON:-83100882,SPD:0.1800000095,CRT:13.0000000000,ALT:313,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0866400051,TOW:0,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1154,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1073,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:1025,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:997,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:980,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:971,***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:966,***
###STABILIZE 1***
+++ASP:0,THH:0,RLL:14,PCH:-14,ch3_in:961,***
!!!LAT:40312658,LON:-83100877,SPD:0.0399999980,CRT:17.0000000000,ALT:314,ALH:0,CRS:175,BER:115,WPN:1,DST:-1,BTV:0.0000000000,RSP:-0.0870789432,TOW:0,***
###MANUAL 0***
I'll attach the .h file I'm using.
I tried adding mux4 pins and moving the wire.  Again, throttle response in manual is fine, but nothing in Stabilize or Fly-by-wire-B.  I checked continuity between the mux and input, mux and output, and arduino (or is it atmel?) and output, and they're all fine.  I'm out of guesses, unless it is a power problem from running off the ESC.
Any ideas?
Robs_EasyStar_header.h
    Try the latest code in the repository and move your throttle jumper to Pin 11.
    Change your header to specify that you want THROTTLE_IN to be 11 instead of 13.
    Good luck,
    Jason
    There is a zip file called test suite in the downloads:
    http://code.google.com/p/ardupilot/downloads/list
    Try the throttle test. Just use the included header and load it up.
    It will print ch3_in and ch3_out.
    You could skip the mux and wire it directly to your servo to see if the mux is bad.
    Jason
    Using the airspeed sensor and CRUISE_AIRSPEED 0 will produce no throttle in FLY_BY_WIRE_B.
    But if you have no throttle in STABILIZE you may have a hardware problem. Look at the telemetry you posted. You can see that in FLY_BY_WIRE_B the throttle value is always zero due to trying to get down to a zero speed. However in the STABILIZE data you can see that it is trying to give you non-zero throttle values.... You could have a problem with the multiplexor. They are known to be a bit sensitive (to electrostatic discharge, etc.) One as mine developed a bad throttle channel which i fixed by rewireing through channel 4
  • have you adjusted airspeeds?
    #define CRUISE_AIRSPEED 0 // If we have airspeed sensor pitch is used to maintain desired airspeed and throttle is used for climb/descent
