I recieved my new APM 2 week ago and havn't been able to fly with it yet. I followed the instructions and it work very well with 2.28 and HIl version. The Mission Planner was 1.1.50. Once I upgraded the Mission Planner 1.1.51 and up it started to act funny with just usb being plugged in. The mission planner would get a no Mavlink heartbeat and also terminal would be stuck on Init Gyro. I would let it sit for couple of hours without power and reconnect. Everything was working for 5 mintues and with the board still on the table the gyro stopped working again. I tired to go back older firmware and mission planner with no success. Even updated the ppm decoder with the 2.26 hex file and still no success. The APM 2 still works in HIL firmware without any problems. I have followed many other forums that had similar problems however none where a fix. I tried arduino ide 2.30 firmware and mission planner version. I turned on the #define APM2 code line to make sure the it was correct. I can't get the Init Gyro to pass. I don't want to removed the daughter board and if I need to I will send it back to get fixed. I also have tried the flashcard removal and resets and erase with no luck. I havn't even flown the board and it allready bad. Any help would be nice.
My copter drop from sky as rock and after that gyro did not init. https://www.youtube.com/watch?v=pZkNGRJBKOk
I have read same kind issues with APM 2.0 that copter just fall off sky without any warning and after that gyro does not work. It looks that if gyro fails it not only put copter to unstabilized mode it hang whole code and shutdown motors. I hope that this is fixed in new code.
I think I found the problem. I flashed a flash light in the middle of the daughter board and APM and there is a white chip moving around kind of losely. I think that is my gyro problem.
Also upgrade mission planner 1.1.54 same results.
