Hi!
I build kit arducopter quad, and go to test it.
But GPS don't work.
I try everything,
1 reset APM,
2 erase APM,
3 upload 2.8.1
4 and 2.9.1
5 I test every pin and wire from Ublox module to APM board, all OK
6 I upload Firmware 7.03 to Ublox, and upload config to Ublox
7 I test Ublox works fine with u-center 7.02 and lock sattellites
8 I connect Ublox to APM, and "NO GPS" message still appears.
9 I use Terminal, TEST>GPS , and only dots ........
I think problem with APM.
I don't know what to do.
What do you recomend to me ?
Did you solve your problem?
I just received my LEA-6h with firmware 6.02 and I don't know if I should upgrade to 7.03 like you did.
I just bought AMP2.5. "No GPS" for me was because I used wrong cable for the old style GPS. After I used right cable for the new style GPS and plug in to the right port, I made my GPS working. Hope this helps.
