Has anyone successfully used the APM2.5 (or other APM) with the cheaper NEO-6M ublox gps ?
Did you need any modifications to the source code ?
Thx !
Thx !
i,m trying again today, i have tried to use the tele and power it up with the wall charger i place the antenna of the gps far away from the tele and still NO GPS on the planner, then i plug the apm to the pc still with the tele connected(which will not work because of the usb) and i got GPS NO FIX so obviously is the tele the problem, how you guys suggest to resolve it?
thaks
ok people just a little help for those who have gps lock over usb but no lock on main power.
There are two possible causes to no lock on main power, firstly the amp internal power circuit is not high capacity so if you have everything powered from the BEC's of your speed controllers, if they are low current becs you will find that the power is insufficient to power the whole board, at one point i had a bard that worked until the motors powered on, at which point it would loose its power and brown out.
Secondly you may have interference, the stock gps is very sensitive to interference from the motors and even from the wires running to the ESC's, so make sure to mount it at least 2 inches away from wires and even further away from the motors.
hi guys i got a small situation here, and i wondering if anyone got the same, it seem that if i got the telemetry connected the unit doesn't see the gps, but if unplug the telemetry all working,
any help?
thanks
hi all it turn out the i got one cable broken so i can't connect, can someone tell where i can buy one cable for gps, is the same as the telemetry one
thanks guy i manage to get all working no i got 3d fix from the gps pluged on the APM 2.5 but i got a small issue now, on the planner it show that is moving but actually is on the bench, is it normal?
i got some life today and i manage to get some file transferred to the gps module but still no fix signal, see the pics attached, where i missing something?
can someone tell me what the right connection when i swap rx with tx one time the planner tel GPS: no GPS and another time GPS: no Fix, i'm just trying to figure it out which is the right one
can someone tell the pinout colour code to connect the ftdi cable to the gps? because i believe that's he first thing i'm wrong
thank you
Nobody got any ideas what I'm doing wrong?
the ftdi cable is arrived today but still not luck this is the error code that i got when i try to flash my gps, anyone can direct me on the right direction?
thanks
2
3
4
5
6
of 6 Next
