ive got a tricopter that ive just fitted an apm 2.6 to, i had it setup ok and flying ok till i tried to do a save trim operation on it straight after that it just got erratic.. it flys for 30 seconds then seems to cut power then it wont disarm correctly , i have to disconnect the battery then reconnect but it just does the same again .. is it something corrupted since itried that trimming session? thanks
@glenn,
If you have either tlogs or dataflash logs available it would be good to make them available to help troubleshoot your issue.
TCIII Admin
