APM 2.8 issues
Greetings all!
I recently switched away from the HK KK2.0 to the APM 2.8 with the DShot 3DR Radio.
Here is a picture of my setup
Here is the FC that I'm using
And here is the radio
I'm running into two issues.
The first is that it seems that the APM wants to re-initialise when I arm it and during flight.
The second is the "DCM Bad Heading" message.
Below are two different flights of the same machine.
[MAV 001:1] Initialising APM... [MAV 001:1] ArduCopter V3.2.1 (36b405fb)[MAV 001:1] Frame: HEXA
[MAV 001:1] Log erase complete
[MAV 001:1] Calibrating barometer
[MAV 001:1] barometer calibration complete
[MAV 001:1] GROUND START
[MAV 001:1] DCM bad heading
[MAV 001:1] ERASING LOGS
[MAV 001:1] Erasing logs
and
[Coptar:1] ArduCopter V3.2.1 (36b405fb)[Coptar:1] Frame: HEXA[Coptar:1] Initialising APM...
[Coptar:1] Log erase complete
[Coptar:1] Calibrating barometer
[Coptar:1] barometer calibration complete
[Coptar:1] GROUND START
[Coptar:1] Lost GPS!
[Coptar:1] DCM bad heading
Things that I've done to try to solve the problems:
  • Removed JP1 (because I'm using the power module)
  • "Cut" all +5v lines from my ESCs (I only had one set up anyway as a holdover from my KK2.0)
  • Re-calibrated the compass module
  • Reconfigure the compass module (I found that it had a "Roll +180" setting attached. I reverted it to "None")
If you look at the picture, you'll see that the GPS+Compass are pretty far away from any interference (IMO).
Any help/direction would be greatly appreciated. I'm so stoked to get this thing fully up and running and this seems to be my last hurdle!
