APM 2, 900mhz X-Bee and MinimOSD
Just a little confused on whether or not I can have both the MinimOSD and X-Bee connected to my APM 2 at the same time?  The Wiki states not to connect the Tx wire when using an Xbee module in parallel but I can't find any diagrams on how this should be connected.
Are guys just making a special harness and soldering the xbee and OSD wires together?
Any help or better yet pictures would be appreciated.
    And here is plain diagram of it. jd-ioboard-multiconnection.jpg?width=500
    You can check this doc at jDrones jDoc. It shows how to connect jD-IOBoard, OSD and XBee all on same time. You can find same drawings from my picture gallery under ArduCopter wiring.
  • Look at this link here,
    http://code.google.com/p/arducam-osd/wiki/How_to_start_minim
    The both pictures show a hook up to the APM, But talk about not connecting the TX from the Miniosd.
    I made my own cable, first I got the Cable working for my Xbee, then just ran a 5 volt, GND and TX out from APM to rx of the miniosd off of that cable to the input of the Miniosd.
