APM arming problem
When I arm my APM 2.6, it responds to my controls for only about 5 seconds until the motors start spinning at a low RPM. The motors continue to spin at that speed until I lower the throttle all the way down, then the APM disarms and refuses to arm again.
The strange thing is, when I plug the APM into the computer and connect to Mission Planner, it will arm and disarm perfectly.
These are the components I am using:
APM 2.6 clone (powered by the esc's UBEC)
Q-Brain 4-in-1 esc
Turnigy 9x
Is something wrong with my APM? Am I doing something wrong?
Video (The constant beeping is the from the transmitter's low battery alarm)
https://www.youtube.com/watch?v=wkcWPdLaU3Y
  • EDIT: Fixed it! Turns out I needed to completely reset the board. I'm not sure what was the problem was, but it's working fine now.
  • have you looked at the logs?
    • I tried, but when I try to connect to it in APM
