    Oberon: sure, here is the answer to your VS/VisualMicro compile error:
    http://www.google.com/search?client=safari&rls=en&q=error+P...
    Follow the first links and read for the fix.
    This is not a DIYDrones, ArduCopter, or even an Arduino issue, but I am happy to point you in the right direction. If you read those links, you will find answers.
    When it asks you to "print" hit cancel. Then search for "include_sketch.cpp" on that page, and read every post that mentions it. Good luck.
    error PRJ0019: A tool returned an error code from "include_sketch.cpp" - Google Search
    I think it is enabled now already, on channel 5 for roll, and channel 6 for pitch. See Camera.pde for details. If it does not work, I have a hack you can try. But just connect go to your radio setup, make sure you have channel 5 and 6 configured, then power off, connect servos, and see if it works. If it doesn't work, let me know...
    sorry, backwards, I think it is ch 5 for pitch, and ch 6 for roll
    I should also say that I mean channel 5 and 6 OUTPUT. Channel 5 input is used for modes. I have used channel 6 and 7 in the past, for manual camera control, but I need to read through the code as it is now to understand it all. In any case, give it a try on 5 and 6, I'll do the same here (w/o my ugly hacks)
