APM Connection Problem
(posted previously in Software, meant to post here)
Is there a good reason my APM wouldn't connect in Flight mode but does connect in Setup mode?
I am obedient in moving the mode switch as instructed by the prompt.
It always times out and gives the no heartbeat message.
Was loading a mission, ok, then tried to adjust parameters but won't connect.
Have done every permutation of power up/down, reset, etc, but no go.
Starts with the B and C LEDs on, then when click on Connect, B and C go off, TX blinks 4 times at 2 sec interval, skips one, repeats until times out, then board appears to reset (ABC pattern ending with BC on).
I can always go back to Terminal mode and connect with no problem.
Did an update in APM Planner, reuploaded APM V2.23, no change.
  • Checking mode Switch:
    Pins:
    1 - Nearest DIP Sw
    2 - Center
    3 - Nearest edge of board
    Flight Mode (away from header)
    1: 4.9 v
    2: 4.9
    3: 0.5
    Setup Mode (toward header)
    1: 4.9 v
    2: 0.5
    3: 0.5
    Is this correct? Expected the center pin to be 4.9 v always and the other two to switch.
    Is there a readable schematic posted? (not the Eagle version)
