Alright, so I got my APM on a flying wing (F-117), however...
I have already played aroun with the dip switches to get the elevons to mix right or not via APM.
However... When I go into manual mode, the plane thinks that it is NOT using elevons, and the flaps act idendent as a normal elevator, and rudder would..
But When Im in stabilize mode, the plane knows it is on elevons, and will act correctly! ???
Any suggestions?
Also, what do I do if the plane mixs up its X, and Y axis, and rolls for elevator, and pitches for roll?(also reversed..?)
let me know if you need some video? thanks!!!
the file below is the video demo to show what exactly is happning..
The plane acts perfect while in stab mode! (even under my inputs)
however, in manual it thinks there is no mixing?
