APM + IMU Models??
Hello, I'm looking for a commercial airplane model, type multiplex, etc. which fits the APM + IMU, now I have a TwinStar, EasyStar, and EasyGlider and the only one that can fit inside is hardly in EasyStar that utilizais models for APM + IMU? you can put photos of your models with APM installed? a greeting.
  • here more fotos.
    The speedcontroller sits under the lower deck. Between the decks is cabling and camera control electronic.
    On the upper deck Ardupilot and IMU. The red Velcro is for the GPS. The servos are a little bit heavier then steel balls Multiplex recommends for the tail. The Theropile version needs 30g ballast in front. The canopy is of 0.6mm PET.
    If you like it I can send an Autocad File for the stiffener and decks.m
  • Hello Javier,
    Easy Glider is a good choice.The battery space is good for 2 Lipo cells of 4000mAh which gives you 45min of level flight. I solved the Space problem by moving the rudder and elevator servo to the tail. (see fotos) and vacuumformed a new canopy.
    The tail stiffener and decks are 1mm aircraft plywood.
