  • Same problem, I´ve returned to 3.0.1 without problem. Did you solve the problem?.
    • Can you upload or send the compiled version of 3.0.1? I cannot get it to compile and am having the same issue of no mavlink connection
      Thank you
      • NVM the fix is included in the install file...you have to install new drivers for your system to recognize the external mavlink connection...without these drivers (even if the connection worked previously) it will not work
        This is also true for the mac side
        Cheers
        Alex
