APM RSSI 3.3V input (feature request)
Hi.
The current RSSI_PIN expects RSSI signal from 0V to 5V. The new FrSky X8R receiver has RSSI output signal with 0V to 3.3V levels.
It would be nice if the RSSI_PIN had option to re-scale (software re-scaling) the input level to 0-5 to get accurate readings.
something like
if (RSSI_RANGE is 3.3) then RSSI = RSSI * 5 / 3.3;
This should require one additional RSSI_RANGE parameter and one or two simple lines of code.
As of now, the RSSI_PIN works with X8R receiver but when at MAX it obviously shows only 66% signal strenght.
Thank you,
Brano
  • what's the status on this request?
    I read in another thread that there's a 'dev' version that already has this feature integrated.
    Where can I download a version of APM Plane that currently has RSSI_RANGE implemented?
    Thanks,
    pab'
  • I second this request. It has been brought up a number of times. I hope it does get implemented soon
    Frank
