I am running the latest version of MP (1.2.28) and am getting some strange behavior.
When I connect to my APM (2.5) and refesh the parameters it goes ok.  Once the parameters are loaded the screen goes into a repainting loop as it tries to display.  This seems to be happening a little more each time a load the parameters, like it is looping through files or something.
In addition, ever since a defaulted the parameters back to what it shipped with (CLI->Setup->Reset), I have started getting various "failed" message boxes that I never go before.  For instance, I was tuning some PID's and when I saved and loaded them, I got "Set RATE_PIT_P failed".  I didn't change the RATE_PIT_P parameter.  I was also getting similar errors when I turned on the option for a 3dr battery monitor.
Any help or suggestions would be appreciated.
Steven......
ps - Windows 7.
    thanks for the report. 1.2.29 should fix this. single repaint
    as for your rate_pit_p problem im not so sure on.you are using a new firmware?
