0 apm2.5 blue light only Posted by Quad Papa on December 8, 2012 at 1:31pm I had a pretty big crash. My APM board only shows blue light when connected to USB or battery. It will not reboot. Ideas?? You need to be a member of diydrones to add comments! Join diydrones Tags: no, blue, boot, light, only Email me when people reply – Follow
Thomas, the reset switch seems to work. It will reboot, but the red light that shows armed never comes on. Other lights all work.
Thanks for the suggestions. I will post if I find a fracture. FYI it is the APM 2.5.
@Quad Papa,
Make sure that the reset switch is not stuck in the closed position.
TCIII
You probably fractured a solder connection or solder trace on the pc board.
Do you have access to an inspection microscope?
You could inpsect the board carefully for fractures.
-=Doug
