APM2.5 reverse mounting on a frame?
I'm sure I read somewhere about being able to mount the APM backwards on a frame and that there is a setting somewhere you can set which reverses it 180 degrees in the settings so the APM thinks it's facing the correct way (forward) The reason I ask is because I'm in the middle of a new build and a few of the wires are going to be very messy. By reversing the APM I can get round the problem. Any one know if this is true?
  • Admin
    @Kev,
    This is what you are looking for:
    Board Orientation (AHRS_ORIENTATION)
    Note: This parameter is for advanced users
    Overall board orientation relative to the standard orientation for the board type. This rotates the IMU and compass readings to allow the board to be oriented in your vehicle at any 90 or 45 degree angle. This option takes affect on next boot. After changing you will need to re-level your vehicle.
    Value Meaning
    0 None
    1 Yaw45
    2 Yaw90
    3 Yaw135
    4 Yaw180
    5 Yaw225
    6 Yaw270
    7 Yaw315
    8 Roll180
    9 Roll180Yaw45
    10 Roll180Yaw90
    11 Roll180Yaw135
    12 Pitch180
    13 Roll180Yaw225
    14 Roll180Yaw270
    15 Roll180Yaw315
    16 Roll90
    17 Roll90Yaw45
    18 Roll90Yaw90
    19 Roll90Yaw135
    20 Roll270
    21 Roll270Yaw45
    22 Roll270Yaw90
    23 Roll270Yaw136
    24 Pitch90
    25 Pitch270
    26 Pitch180Yaw90
    27 Pitch180Yaw270
    28 Roll90Pitch90
    29 Roll180Pitch90
    30 Roll270Pitch90
    31 Roll90Pitch180
    32 Roll270Pitch180
    33 Roll90Pitch270
    34 Roll180Pitch270
    35 Roll270Pitch270
    36 Roll90Pitch180Yaw90
    37
    Roll90Yaw270
    TCIII ArduRover2 Developer
