APM2 AND MIN THROTTLE
Hi, I mounted a quadricopter and not risco to adjust the idle speed to the motors, is doing the procedure is automatic and the manual. Basically I can arm the engines but the engines are not running, only run if I raise the throttle stick (the stick at least the engines are stopped).
My hardware configuration:
TURNIGY 9X TX
8CH RX TURNIGY
SKYWALKER 20A ESC
APM2
ENGINE TURNIGY
Thanks in advance for the helpful response.
Luciano
  • This sounds correct. Motors should stop when throttle stick is down.
    You want motors to spin just after connecting the lipo?? Very bad idea.
