ardu rover
I am trying to connect my apm  to sabertooth 2X25 but when i connect it it is not working
1) I installed the ardurover firmware
2)I have connected apm pin 1 to sabertooth pin s2 then pin 3 to sabertooth pin s1
3)Receiver 1 to 1 , 2 to  3, 5 to 8 and 6 to 7
4)But still not working .....can anyone help me with it
  • I have a similar arrangement.
    Does the 2x25 work on it's own without the APM?  Can you check with a 1k , 5k or 10k pot across the inputs?
    I have the 2x25 switches as follows:
    1 OFF
    2 ON
    3 ON
    4 ON
    5 OFF
    6 ON
    Make sure you have a GND wire from the APM to the 2x25.
    I also DO NOT have the APM set to SKIDSTEER.
    If that doesn't help, provide more details of your wiring and settings.  Many here have used the 2x25.
    Falcon
