Arducopter 2.0.24a !ALPHA!
This is my internal not so well tested version of 2.0.24a.
I had hoped to fly it more this weekend, but a bad ESC stopped me Saturday and Sunday I didn't get to try alt hold, which is totally new.
If you are brave and a good pilot, try it. I have implemented some DCM changes to resist drift and correct gyro saturation events faster. I am working with Doug in the next few days to improve this even more. (And don't fly this release without the filter pads soldered up.)
If you choose to fly this, alt hold is the thing to look out for. I have a new mixing algorithm and have increased the baro performance. Expect less noise and less random drift. Please use some felt over the sensor. I don't want to get bad info back from test flights.
I wouldn't try auto or RTL with this code until the basics are proven to work properly.
What's new:
2.0.24
Incremented firmware version to 100
Added motors logging - logs PWM output
Added 6 position moving average filter to barometer
Reduced and filtered temperature readings from baro - the cause of random walk errors
Significantly increased THROTTLE_BARO_D to leverage less noisy barometer.
Removed error limit on alt hold
Combined sonar and baro reading with a mixing algorithm
Combined sonar and baro PIDs into one.
Added auto-level mode - enter by holding motor arm position for 20 seconds. fly as stable as possible at 3-4 feet for 45 seconds.
Added in-field level command - hold disarm for 10 seconds
Increased dead zone on Yaw to prevent backwards turning on crooked airframes
Increased yaw output limit
Added startup message in log
Removed ground_temperature, ground_pressure from EEPROM - not needed
Increased kp_rollpitch in the DCM to .1 (about 2x) for faster recovery
Added dynamic drift control - neutral sticks and lower throttle will trigger higher (1.5) DCM gain. untested.
Fly at your own risk!, a release version will come out next week. I just don't want to hold on to this code too long without feedback.
ArducopterMega_2.0.24.zip
  • Did a quick test with the latest 24 zip.
    Yaw was in option 1  and was very slow. Still have to test other modes.
    I thought I was in Loiter when I engaged the switch. Did a quick check after and found out I programmed Alt hold. Allmost no drift. Also in stable.
    In alt hold, it holds a little bit aggressive with ups and down but between let say half a metre. And it doesn't keep gaining altitude when I forexample put my hand under the sonar. I comes down nice.
    So not bad at all.
    I didn't solder the bridges. (yet)
    I've tried arming for 20 sec ( in flight leveling) but nothing happens.
  • I've just tested latest code. I didn't experience any strange behaviour. BTW I never had strange drifts, but I did had Yaw problems.
    So today I soldered pads and went out testing first old code to be sure my frame was ok.
    I have to say in my last attempt to get a stable yaw, I soldered the mag on one board and inverted on the other, before I had components up and pins forward. Now I am in standard, and actually had no issues on both IMUs (same mega borad).
    So I loaded .24 and did some agrressive flight (only stabilize). No problems.
    I tested the three Yaw options:
    YAW 0: nice and responsive, but a little imprecise on small rudder (tends to stay in one direction even if I give some oinput) it overshoots a little on defaults
    YAW 1: Stable, too stable. Impossible to fly with it. To make a 360 I can count almost to 8 at full left or right. It overshoots at standard PIDs lowering PIds helped a bit but was really unflyable
    YAW 2: Too aggressive! It overshoots a lot but it takes less than 2 secs. to do a 360. Very difficoult to control because very little input gives too power.
    ALT_HOLD I've only tested a little, it looks much better now, it holds very nicely, goes up and down without overshooting. Baro readings probably are still a little jittery maybe a bigger average filter could help a bit (I used 11 or 15 readings in my moving average filter implemented for the ardupiratesNG code.)
    I didn't test the dynamic drift control... I finshed my batteries.
    Last thing. Soldering the pads: actually it seems I can use slightly higher P and lower D values, thus having a more responsive copter.
    Good job Jason & co.!!
    Hope this help.
    Cheers,
    Emile
  • i flew 2.0.24 tonight and alt_hold works for me now.  I tried at 1m and 2m heights and it worked like ardupiratesng. Quad was hovering nice!   I will give it a good test in the morning at a park.  I have gyro pads soldered and fly with default pids on both of my quads.  My sonar is XL-EZ0.  I also have an LV-EZ0 that I will try in the morning.  Quad drifts a little but It is always breezy here.  Yaw works but is very slow.  I compiled with default options except for mag.
    updated the DCM gains, and fixed the alt hold log to give the integrator value for baro.
  • Jason,
    Just compiled, loaded the code, erased the eeprom, setup radio, sonar (XL-EZ0), compass, leveled, and set modes to stabilize, simple, Alt hold, and loiter. I also have a small block of foam over the pressure sensor. Sonar output in test mode looked good as well as the compass. I checked the motor outputs without the ESC's plugged in and everything looked good in "+" configuration. I did 1 test flight before it started raining here. Stability/yaw was good in stabilize and I did some flying around in the back yard. The wind was gusting a little, but I did try ALT-Hold. My first try, the quad rose 10 or 15 feet before I switched back to stabilize. The second try after resetting was a little better.  It held for about 15 seconds and then rose again slowly.  I tried several more times and the remaining times, the quad held briefly at around 5 feet and then slowly dropped to the ground and touched down softly and then flew up again to 4 or 5 feet.
    I did try to disarm and rearm for 10 seconds in the middle of the flight to test the level - but I didn't see a pattern in the lights so I just resumed test flying the Alt-hold.
    On 2.23 I tried Alt-hold with the sonar and it always dropped to the ground slowly.  When I disabled the sonar, it held pretty well +/- 3 or 4 feet.
    Anyway, I've attached the log and will try some more flights tomorrow if the wind/rain cooperates.
    Heino
    13-06-11 07-59 1.log
    I downloaded and compiled it. Worked OK. Can you retry and restart Arduino after updating the library path?
  • good job jason and thank you
    Seems like there were some compiling issues. Solved by an update and latest Arduino build 22. (I'm going to delete the support comments to make way for flight comments.)
