Arducopter 2.0.25
I have been testing the latest BETA software.
The the compass is behaving normally in all positions
Stabilzed mode is working well after retuning YAW setting.
Loiter is functioning a lot better than it was in Version 2.0.23 stable and tight position.
But I am having a problem with RTL.    When I change mode from Loiter to RTL the quad goes at 45 degree angle straight for the ground.  Increasing the throttle does slow the descent rate a little.
What  tuning can I do to resolve this RTL mode,  or do I have some other setup problem.
David
    If you can output the flight log I can help. Thanks
    Jason
    Sounds like you've got the RTL altitude set wrong. You should have "hold default alt" checked, some reasonable "default alt" (say 30) and "absolute alt" unchecked.
