Arducopter wobbles a lot (video)
Hi everybody,
Video : https://www.youtube.com/watch?v=Wcjm-07PsWg
First of all I have to point out that i checked following page:
https://code.google.com/p/arducopter/wiki/AC2_Troubleshooting#ArduCopter_tilts/flips_over_or_wobbles_crazily_when_I_try_to_tak
Possible problems to check explained on page linked above :
1 - Board facing : CHECKED
2 - x mode : CHECKED
3 - Motors turning right way : CHECKED
4 - Dont know what does it mean since already checked motors turning right way
5 - Propellers are attached tight : CHECKED
6 - Gyro/Compass calibrations : CHECKED
7 - ESC Calibration : CHECKED
8 - Radio Pitch/Roll is 4200/4100 not exactly 4500. Might be the problem.
9 - All sensors are working as expected. CHECKED
Preflight checks : DONE,
tries to compensates rotation : CHECKED
pitch/roll control : CHECKED
So what should I do now?
Earlier i played with range of transmitter sticks. Made all of them -120% +120% Then i played with subtrim settings to get them to center.
3600MAH 4S 30-40C
HK BlueSeries ESC 40A
NTM 28-26 1000kv motor
GWS 1047 Propellers
  • test stabilize p 3800
  • Test Video after PID Tuning : https://www.youtube.com/watch?v=J2J528xn-AY
    Video while PID Tuning : https://www.youtube.com/watch?v=GQUswqanMis
  • I managed to resolve it by lowering P values in Stabilize/Rate sections for both Pitch/Roll. But there is still little shifting on yaw axis.
  • Did i post it to wrong category or something? :(
  • Now I just added some foam between APM and frame. Wobbles decreased but still unstable.
    It yaws to the left a bit, I compensate it with yaw stich while flight but still rotors wobble 3-4cm up & down.
    I managed to elevate it to 1 meter height and switched to auto-land. Auto-Landing works but it is very wobbly too
