ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        Richard,
        No, it's not possible to use two external compasses on the Pixhawk.  The reason is that the hmc compasses have fixed I2C address and the Pixhawk only has two I2C buses.  Just as a reference, this limitation is mentioned on the compass module wiki page although I don't expect that everyone can find every piece of info on the wiki very easily.
        By the way, I've recently found that the fail-over to the backup compass does not work.  I have a fix but I'm reluctant to put it in to AC3.2 because of situations like yours where failing over would actually cause problems.  Instead we will make a more comprehensive enhancement that makes it possible to set which compasses can/cannot be used.  That change will probably not make it into AC3.2.
  • Devteam,
    I just loaded AC3.2-rc9 should I re-calibrate it again? The reason why I'm asking this is that, GPS can't get 3D fix, hence I can't arm it. I don't know if it's just me but I read it before that there's a need to tweak some parameters, but I can't remember where's that thread now. Strange because I haven't encounter this in AC3.2-rc7. By the way have 10 or sometimes 12 satellites and I'm in an open field!
    Anyway, I'm using Pixhawk with ublox LEA-6H.
      Jay,
      Depends which version you're upgrading from but if it's -rc7 then there shouldn't be any need to do any recalibration.  I'm very surprised that with 10 or 12 satellites it's not getting a GPS lock.  I guess maybe you mean the GPS HDOP is >2.0 so you can't take-off in Loiter mode?  Is any reason showing up on the HUD for it failing to arm?
      • Thanks Randy for this reply.
        As I mention I've been using rc7 and i had no issue except for the know pulse positive and other known issues. I moved to rc9 recently, I didn't do the calibration and I didn't adjust any of the parameters as well. This time I can't arm, unfortunately I didn't bring my laptop to check my hdop reading but I have my minimosd so I can only monitor satellite reading and other information. Anyway let check that later.
        Again thank you.
      • Randy:"Depends which version you're upgrading from"
        I think it is your plan to have an "upgrade" to-do check-list from 3.1.5 (current released version) to 3.2 (next released version), right?
          OwlPic,
          Yes, we've already discussed this via email.  Txs
  • This reply was deleted.
      • Seems to me it can be improved on. After all it is a tri-copter after losing one prop. Use the three forces to keep it level. Vary alternative rotating props to correct yaw. Reduce the speed to lower it down.
            • Is there a better place to discuss this? Like to hear your thinking and explain mine.
      Terry,
      Yes, that would be a very cool one to do.  I'll put the equivalent for the hexacopter on the to-do list for AC3.3 but I can't make any promises.  The truth is that I can't do it on my own because I've already got too much on my plate.  Some other developer will need to do the heavy lifting.
      • Does it mean, that a Hexa or Octro Copter based on Arducopter is not able to fly with one Motor failed?
        That is the only reason to fly more than with a quad, to have a failsafe if one Motor cuts!
        http://www.mikrokopter.de/ has this failsafe from the beginnig of providing hexa or okto Kopter.
