Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
This version will be pixhawk modem xbee868 for me?
Is Px4flow become active?
Thank you in advance for your answers,
MErdi,
The PX4Flow is still not supported in AC3.2. There is some active development going on so I'm pretty confident that it'll be supported in AC3.3 and it will add real value.
AC3.2-rc11 is now available through the mission planner’s beta firmware’s link. The changes are in the ReleaseNotes and also listed below. Changes from 3.2-rc10
1) reduce lean on take-off in Auto by resetting horizontal position targets
2) TradHeli landing check ignores overall throttle output
3) reduce AHRS bad messages by delaying 20sec after init to allow EKF to settle (Pixhawk only)
4) Bug fixes:
a) fix THR_MIN scaling issue that could cause landing-detector to fail to detect landing when ch3 min~max > 1000 pwm
b) fix Mediatek GPS configuration so update rate is set correctly to 5hz
c) fix to Condition-Yaw mission command to support relative angles
d) EKF bug fixes when recovering from GPS glitches (affects only Pixhawks using EKF)
It’s possible this is the final release candidate. Personally, my only remaining concerns are:
Thanks for all your help in testing!
Andre,
Yes, the Relay should still be supported on the APM1. The issue is that there are now up to 4 relays supported so I think in your userhook_mediumLoop you just need to change the call to AP_Relay::on() to AP_Relay(0). Also I've updated the Relay wiki page and it's got a screen shot of another parameter you'll need to set to specify which pin the relay is using.
Andre,
The dev list is drones-discuss@googlegroups.com.
Andre,
Yes, just send the issue to that email list. Your first post gets moderated so it won't appear immediately. Then I'm sure someone will answer. I can't guarantee the answer will be helpful but you'll likely get a response! The email list is completely open so all posts and replies can be seen publicly. I have it delivered to my email box but i think there's a web page to view replies as well.
Andre,
It's a real challenge to get it to fit on the APM1. I've turned off sonar for the APM1 for -rc12. Best of luck. By the way, this discussion should probably move to the drones-discuss email list because it's really more of a dev question.
I wish 3DR would do that! That's one thing a DJi Phantom has that makes great sense. Just from the lights UNDER the quad you can know the battery life and if you have a decent gps count.
I could upload AC3.2rc11 on my APM1.0 by Mission Planner.
The result is;
1) Mediatek GPS is not recogized
2) Altitude becomes crazy, climbs up more than 50,000m high:-(
It looks like GPS becomes crazy.
Unfortunately, I have removed compass for APM2.0.
Hattori-san,
Ok, thanks for that. I think the code has gotten too big for the APM1 so we will need to trim it down just a touch.
91
92
93
94
95
of 262 Next
