ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • What GPS did you use before? How is it compare to LEA-6H?
  • fellow drone flyers, i want to update a correction here. i had reported about 15 days back the simonK based 20A afro ESC and BLHeli based sunrise 20A ESCs are having sync issues with Pixhawk loaded with AC3.2 firmware. I would like to post here that none of the ESCs had sync issue. The problem was with one motor of which i had no idea. i never thought that a motor can glitch without any apparent reason. the motor was turnigy 2830-980KV. they are wonderful motors. Out of the nine motors i bought only one was glitching and all this time i was busy changing the ESCs. after replacing the motor i had no issue at all while flying pixhawk with AC3.2-rc2 update. the motor could have magnetization problem (not sure). all modes are excellent. the navigation is superb. RTL always within 3m of takeoff. my apologies for posting wrong information.
      Ravi,
          Great, thanks for the correction!
  • Hi,
    I would love if someone could give me an estimate time when the rc3 would be available?
    -Rai Gohalwar
  • 3.2 RC2 has been great so far but I think Autotune needs to be improved to support large copters with large props and low kV motors. I fly a 830mm Quadcopter with RCTimer 5010 360kV motors on 6S with 17x5.5 props and the autotune is not able to tune the copter properly. But other than that Arducopter 3.2RC2 has been great overall even though its still in beta. I hope someone can fix the autotune though. My older 550mm quadcopter autotunes perfectly and flies really well. I have attached a log and some general pictures of the quad itself if any developer wants to analyse. Though the log is from 3.1.
    Regards
    Chandruth
    Large Quad data.zip
    • Hi Chadruth, I am in the process of building a similar quad only using Sunnysky 340 kv motors. My Tarot 650 (APM 2.6, 14" props) flies well but took 3 tries to get autotune to complete and is a little twitchy. I'll be interested to see if I can get autotune to work on the bigger one. Would you mind sharing the pids you are using for your large quad?
      • Hi Terry
        I used the Autotuned gains then manually changed the Stabalize Roll/Pitch P gains. I have attached a screenshot of the gains. The PID Rate gains were from autotune. I only adjusted the stabilise P gains.
        Regards
        Chandruth
        https://storage.ning.com/topology/rest/1.0/file/get/3702656472?profile=original
        • Thank you for sharing those. It will probably be a month before I have all the parts and get my new quad together and I'll let you know how it works. I'm using a pixhawk so it will be interesting to try it out. Maybe 3.2 will be live by then... looks like some wonderful work being done on it.
  • I did seven WayPoint flight with 3.2 rc2 spline curve mission.The flight path was around the tree with single point of interest. Video is somewhat shaky because my gimbal mounting is to flexible. There is slight twitch when copter hit WayPoint but all in all good start.
    Arducoter 3.2 beta spline curves ROI from Dusan Trenic on Vimeo.
  • Ran my first 3.2 rc2 Spline Way Point APM Y6 flight this evening.  Had 14 way points and did not do much change in elevation.  Seemed to go smoothly, but did notice some wobble at WPs. Video is uploading right now.  Should be here https://www.youtube.com/watch?v=24ROAfNNnoo&feature=youtu.be in about 1 hour.
