ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      Steve,
         I missed this message but here are some belated answers:
           - the take-off command does not need a lat or lon set.  these won't be used even if provided in the command.
           - land accepts a lat/lon but it's not required.  If you set them it will first fly to that location and then land there.  If not provided it will land at the current lat/lon.
           - you should be able to open up the mission's .txt file and change the regular waypoint command id "16" to the spline id "82".  Of course I always do this through the mission planner's flight planner screen by changing the drop-down.
  • I've been flying quad following setup by ArduCopter3.2 rc9, EKF on and off.
    After auto-tune in the calm weather, the quad becomes shaky.
    3701829814?profile=original
    Stability of position hold mode is incredible that almost no move, just 10 inch cubic error.
    Motors: MultiStar #4108-600KV
    Propellers: 14inch -carbon
    FC: Pixhawk-original 3DR parts
    Speed Control: MultiStar 45A / SimonK
    LiPo:  Zippy 4S-20C/3000
    Fram: Based on Zion-enroute parts
  • Hi Randy, I have just upgraded to rc9 and now I am getting just Alt Disparity warning on arming and I cannot arm.  What do I need to change to fix this?
    • ok, got it flying by deselecting EKF.  It is only very random.  It allows me to arm most of the time with EKF selected.
      Tested, stab, loiter, pos hold and drift.  All very nice apart from Drift as drift apples the brake sometimes during forward flight .
  • hi AC 3.2 user, i strongly suggest that you balance the props precisely. the difference is tremendous. the  damping tapes are not well tuned to the frequency of vibrations (and resonance) which results in many type of errors.
  • I'm not shure if a issue, I program a radio swich to land with 3.15, I try and all works perfect, I try with my new Tarot650 and again good, today I change trottle params as you recommend to this vers as standard and when I try again, motors stop to spin, I try with the other cuad and same problem, can someone confirm this? or only I made a mistake, Thank's.
    The new trottle params are better for my cuads thank's for all work here. :)
      Cala,
           Are you testing with AC3.1.5 or AC3.2?  This thread is really only for AC3.2 beta testing issues.
           I think you're saying that after adjusting the throttle parameters as they've been adjusted for -rc9 (i.e. THR_RATE_P to 5.0, THR_ACCEL_P to 0.5, THR_ACCEL_I to 1.0), the vehicle doesn't disarm when landing?  It's very possible you're right.  A person from 3DR reported the same thing and we looked into it and it was related.  This was an attempt to reduce the jumpy throttle a couple of APM2 users have reported but it hasn't helped so if people are seeing landing problems we will probably revert the params back to what they were for AC3.1.5 'cuz it's hurting and not helping.
      • Yes, testing with 3.15 because I'm not an expert flyer, using the stable releases for the moment (but anxious for new things ;) ) , my copter was little nervous so I change params that you mention and goes better but, with the copter flying, I switch to land and the motors stop in the air, (aprox3-4 mts alt) I can switch again to stabilize and motors begun to spin again and  avoid crash damages (good luck), (the new one was near the floor)
        I'm not shure if post here or at 3.15; I posted here because I used TRH3.2 changes when I detect the problem, please move or delete if you consider better at the other post.
      • I might have had this problem this evening. I did an RTL and my quad landed properly but I'm not sure that it wasn't going to spin up again. I stuffed it into stabilize and took off so I'm not sure if it was me or something the FC was trying to do. APM 2.6 and rc9. If this sounds like the problem and my logs would be helpful let me know and I'll upload them tomorrow. I don't have time tonight.
  • Hello Randy
    today I have tested RC9.
    Pixhawk
    Loiter - OK very well
    Stabilize - OK very well
    altholt - OK very well
    Spline WP OK
    pos.holt OK
    ROI OK
    takeoff OK
    EKF like before very flatly
    canal 7 countries functions in Loiter, altholt
    does not function in Pos.holt.
    This becomes the best version I has ever flown.
    Thanks to the DEV team and Randy
