ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Could it be turbulence (z axis only)? I was flying very low to the ground at about 1.5-2m head into the wind to check how footage would be affected by this...
  • Randy, recently I had an issue when my copter running AC3.2 went full throttle, while I fully dropped throttle. I believe this issue is vibration related, however I have no idea what was the source of the vibration since for the previous 14min+ copter flew with vibrations under 0.5, more interestingly the only vibration axis which goes mayhem is Z axis on both IMUs. I will be attaching a log of this accident, its a lengthy one (I was checking new gains on a gimbal) and the interesting part is between lines 194 - 200. The exact moment when my RCIN3 goes to 0 and alt goes to 60m is in the lines between 195.4 - 196.1
    After the flight it shows that copter flipped after landing, not sure if it is related to the delayed disarm or wind or grass, but no damage was done and I checked each and every piece of equipment on the copter everything was attached firmly, this is also proved by the lines 198+ in which all vibrations return to their normal 0.5 values..
    2014-12-31 07-56-37.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3701903583?profile=original
  • This reply was deleted.
    • I attempted ACC calibration this morning at -2C was not able to do it, copter went fine through the calibration process when I came inside.
  • I'm again with the same issue but do another test, I fly in simple mode, when I go to my left little quick the cuad loose altitude and recovers when I stop, instead to rigth is a rock solid altitude, if I rotate the cuad, nose to left, same problem when I fly to my left (but the front of the cuad, and same thing if I rotate the cuad to the other side so, I suppose I discard the bubble problem; someone have same problem and resolve it? Thank's
    2014-12-15 19-29-12.log
  • @Flyhigh
    This can happen if you bump or move your trims. I would suggest you zero you trims and do a radio calibration and see if that does the trick. If nothing else you can then rule that out.
    • Right before trying position hold I had trimmed my quad using set trim. Then re centered my trims on my radio. So i'm positive my trims were centered when I tried position hold.
      • Logging could be turned up so we can see more information.  I use Pos Hold all the time and it's works just fine.  I'm using it with EKF turned on.
        Turn up the logging and fly with just Pos Hold and post the log.  Something is causing the copter to pitch forward.
        • Could you be more specific by "turn up the logging" is there a faster log refresh or something I should adjust?
          • Your logging is set low.  Set it to Nearly-all so we have more data.
            Log Bit Mask
            • I recalibrated radio in mission planner yesterday per Randys advice. I took a flight today and position hold seemed to be working fine. So im assuming my issue was not having performed a radio calibration recently. I've attached my log files just for the hell of it.
              6.BIN
              https://storage.ning.com/topology/rest/1.0/file/get/3702874707?profile=original
