ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          • I think this is where the 16-2 comes from.... magnetometer is not getting calibrated correctly.... either MP fault or the way rc4 handles/provides data from mag to MP during calibration. so when the new EKFCHECK function catches discrepancies it throws an error, in addition if the discrepancies are large enough copter looses direction control.
      • here is a log where it seems error 17-1 switched me to land. At the time I thought it was a radio failsafe. I was not flying with EKF enabled.
      • more flights today and same errors with the param adjustments suggested. should I be concerned?
        new error message 17-1. what does that mean?
      • Been flying a DIY Hex, all 3DR components including PPM encoder, successfully with all s/w through rc2 for 2 years.  Thanks!
        rc3 and rc4 won't work. Loaded rc4 again tonight, did all setup and cal, including ESC (all at once and individually).  Funky motor behavior.  Don't get familiar "2 beeps" at power up.  Arms, but motors don't spin.  No throttle response.  Reloaded 3.1.5 without changing anything, and I mean anything, flys perfectly.
        Logs attached, help/insight appreciated!
        2014-08-04 17-26-06(rc4).log
        2014-08-04 17-46-32(3.1.5).log
      • i am running it on apm2.6 so, does it mean that some form of EKF is getting on the apm too?
      • Ok thank you. Just curious - when the error occurs, does it execute any type of failsafe? or it's just notifying me? Just want to be sure I don't have a catastrophe in air..
    • This reply was deleted.
        fabio,
        Any chance you have a dataflash log?
  • scratch-build tricopter -- everything checks out well after ~ 8 flights.
    Only one issue - Using channel 8 as LAND - it will no longer disarm once it lands from loiter, drift, pos hold, alt hold - it just lands and motors run in a higher than idle state and seems to be trying to maintain level but does not have enough throttle for flight.  It will land/disarm only if from Stabilize.
    APM 2.5 w/external compass
    • Also, when taking off (stabilize mode), the tricopter always yaws a consistent ~20-30° clockwise. Once I back off the throttle to maintain altitude, etc...  all yaw movement is as normal and rock solid.  This has been happening with all 3.2 rc releases. I have not tried taking off in other modes yet.
      • to fix yaw issue at take off - bump yaw-p value, keep in mind that the higher yaw-p values will cause much faster yaw response which could lead to oscillations as well as it increases vibrations, due to excessive servo movement. what I figured out is that more relaxed yaw-p, in my case 1.5, leads to CW yaw at take off, however produces much smoother flight overall.  Also, if you take off in alt-hold/loiter/pos-hold this CW yaw is vertually unnoticeable.
