ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Randy,
          Ok I've changed all instances of "relay.on()" and "relay.off()" to "relay.on(0)" and "relay.off(0)" in my UserCode file and it's compiling, but sadly it's coming in too big now at 278kb.  Are there any other features I can choose to disable apart from the ones listed in APM_Config.h?
          • Disabling the sonar only dropped it by 4kb - I need another 16kb to get it under 258kb.  Someone else mentioned something about disabling unused flight modes perhaps; is that possible?  PS: Can you point me towards the mailing list perhaps? Thanks
              Andre,
              The dev list is drones-discuss@googlegroups.com.
              • And excuse me if I'm asking dumb questions but do I just send my concerns or questions to that address or how does it work?
                  Andre,
                  Yes, just send the issue to that email list.  Your first post gets moderated so it won't appear immediately.  Then I'm sure someone will answer.  I can't guarantee the answer will be helpful but you'll likely get a response!  The email list is completely open so all posts and replies can be seen publicly.  I have it delivered to my email box but i think there's a web page to view replies as well.
                  • Thanks, will draft
            Andre,
            It's a real challenge to get it to fit on the APM1.  I've turned off sonar for the APM1 for -rc12.  Best of luck.  By the way, this discussion should probably move to the drones-discuss email list because it's really more of a dev question.
      • I add some custom code in order to use the relay to control my LEDs as a voltage indicator - hence I need to manually compile through Arduino each time...
        • I wish 3DR would do that! That's one thing a DJi Phantom has that makes great sense. Just from the lights UNDER the quad you can know the battery life and if you have a decent gps count.
      • I could upload AC3.2rc11 on my APM1.0 by Mission Planner.
        The result is;
        1) Mediatek GPS is not recogized
        2) Altitude becomes crazy, climbs up more than 50,000m high:-(
            It looks like GPS becomes crazy.
        Unfortunately, I have removed compass for APM2.0.
