ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • What is your Frame Type, Quad X or Quad H??
      • H Style
        • Your frame looks to be extremely similar to mine (Xplorer Pro 500, see http://www.rcgroups.com/forums/showthread.php?t=1994987) - isolated sections and all.  Have been flying it with APM 2.6 and now PixHawk, firmwares from 3.1.xx to now 3.2RCxx. Absolutely rock-solid - I have always upgraded FW, started with default PIDs and then auto-tune, maybe 10 times in the meantime. Never a problem
          BUT I have always used frame type X - not H
          Maybe worth giving that a try ?
          • Yes very similar. Josh posted some settings that I'm going to try tomorrow. #2880
            I used H just because the picture of the frame on Frame Setup was most similar. All my other quads use X style. I could change to V but don't want to take it apart just yet. What problems did you find, if you set it to H style?
          • I plan to build a Cinetank too (with an APM). What is the difference between these configurations and what are the avantages of one over the other ?
    • Interesting frame. There are PID settings on the website you gave, do they not work well?
  • Today I was trying the ArduCopter 3.2-rc4 01-Aug-2014.
    Unfortunately the Spektrum Satelite was not working anymore. Back to 3.1.5 It was fine again.
    • Andre:  I am having similar issues.  Mine worked fine through -rc2, but it will not work with -rc3 or -rc4.  What are your symptoms? When did it stop working? I am back to 3.1.5, but I really need sonar...
      Mike
      • I only tried 3.1.5 and 3.2-rc4. With rc4 there were absolutely no receiver signals. Also in MissionPlaner I could´t find anything to enable the satellite or similar.
        I was only trying the rc4 because of this Issue: HDOP mixed up with PDOP I thought It would be solved in rc4 but it is not!
DIY Robocars via Twitter
Sunday
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
