ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hello Randy
    is reset to armed yaw available in the next version?
    for beginners this is a great help.
    regards
    Rainer
      Rainer,
      Ok, we've talked about it on the dev team and we're thinking about adding it back only for Loiter & PosHold modes but leaving it off for Stabilize and AltHold.  The idea being that we should keep Stabilize and AltHold simple because they're fallbacks for the other flight modes.  How do people feel about that approach?
      (randy braces himself for the negative reaction)
      • All of the modes please. This for me is fallback in itself - to regain a sense of orientation if anything goes wrong in any mode.
        Don't have much time to think about whether the mode I happen to be in at the moment is possibly enabled for the good old "show me your a...." switch :-)
          Sam,
          How about just enabling simple mode on a ch7/ch8 switch instead?
          • I'm using this trick and work great for me ;)
          • Point taken. Last time I looked I got the impression I would have to somehow select/declare all modes I would like to have simple mode active, so I used reset-to-armed-yaw - seemed less complicated then. I will re-visit  GUI/docs and reorganize my setup - just that old habits die hard
      Ok, thanks for the vote to have it in.  which flight modes do you like to use it in?  stabilize, althold, loiter, poshold?
  • On APM Planner v2.0.14 on the Standard Params page there is Channel 7 option(CH7_OPT) that I have set to EKF but when I go to Extended Tuning page, it says "do nothing". Full Parameter List shows it has value of 20 so I know it's getting set but probably APM Planner doesn't have the full list of options on the Extended Tuning page.
