ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • It is important to calibrate your ECS, the easy way is all at once
      http://copter.ardupilot.com/wiki/initial-setup/esc-motor/
      and do the full harware calibration
      http://copter.ardupilot.com/wiki/initial-setup/configuring-hardware/
      • Alas, I have done both many times, but thank you!  I have calibrated the ESC, per both the "all at once" and the "individual" procedures prior to flying with 3.1.5, and they worked normally, and it flies perfectly.  I did not think they need to be re-calibrated just because I load 3.2-rc3 or -rc4, so I then load 3.2-rc3 or -rc4 and they do not work.  I then reload 3.1.5, without ESC re-calibration, and they work.  If I re-calibrate ESC with 3.2-rc3 or -rc4 loaded, by either method, the calibration appears to work, but the strange motor behavior is still there when I connect LiPo and try to fly.  I am fairly sure the ESC re-calibration worked when -rc3 or -rc4 were loaded because I can reload 3.1.5 without re-calibration after trying (and failing with) -rc3 or -rc4 and the ESC behave normally and it flies perfectly. The ESC simply do not work properly when -rc3 or rc4 are loaded.
        • that happens because the default pwm output values are a little bit different on each version, so when you power the copter with the new version, the ESC don't like the new values
          • I tried someone's suggestion, hold down safety switch when applying LiPo power. Did not work. So I tried it re-calibrate ESC all at once. Didn't work. So I tried all at once calibration, holding down safety switch with throttle up to start calibration. Didn't work. So I tried it several more times, each time holding down switch when applying LiPo power, alternating between throttle up and down. ESC never entered calibration mode. Suddenly,once when the throttle was down, it armed and all motors ran! Kept it hooked up, took it out, had my first -rc4 flight, amazing! Have not been able to get it to arm and turn props since... Many attempts to repeat - no go... Might be a race condition in the software somewhere...
              Hi Mike,
              There really shouldn't be any need to re-do the calibration from 3.1.5 to 3.2.  No offense to Javier but as far as I know, there should be no changes to the pwm being output with each version.
              I wonder if it's possible that it's tripping over an arming check.  If you connect it to the mission planner and then arm it (without the battery connected) does it arm?
              • Hi Randy! Just loaded -rc5, ran through all set up's, cals, etc., it arms normally and flies perfectly! Detailed testing and tuning commences... Thanks, sincerely great work!
              • Thanks Randy, tried to reply over iPhone, not sure if it worked, sorry if there is a duplicate message...
                Yes, just checked again, it always arms via MP without LiPo, no warning messages.
                I have since been able to get it to arm and fly twice (out of 50 tries) by some combination of holding down the safety switch for a period of time when and after connecting the LiPo. It does not seem to be deterministic, or I have not found the correct pattern. I can tell when it will work because of the beeps. No beeps, no work, 2 beeps, it flies!
                When it flies it is amazing, hats off to the Dev's!
                • Hi Mike, i am just curious... when you fly do you first connect to the Mission Planner via telemetry? Simple because, i think if the copter doesn't arm there should be message in the Mission Planner showing why arm can not be done....ex: bad compass health, magfield, etc.
  • Hi Randy. Thanks for updated wikis and 3.2r4. I have put in several hours of flight time using Pixhawk+EKF in both my hex and quad and have enjoyed every minute of it..Fantastic..
    I purchased a MB 1242 IC2 sonar but using the parameter values in the wiki and connected to the IC2 connection strip along with the compass and ext LED. There is no indication of function under the MP status tab with sonarrange and sonar voltage both 0.. I wired the 1242 with shielded cable and the noise filter..
    I guess my question is-- rc4 capable of IC2 sonar?
    Sandy3701806919?profile=original
    • Hi Edward,
      your params seem good but I think you should not use a noise filter with the I2C one as noise filter is designed for analog sonar.
      As you can find in the I2C wiki, wiring is direct on the I2C port...
      http://copter.ardupilot.com/wiki/common-rangefinder-maxbotixi2c/
      And normally both I2C and analog will work with 3.2-rc4.
      J.
