Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Thorsten,
If you're up for testing it, could you also test AC3.1.5? I'm pretty sure you'll find the same issue is there as well.
Randy,
yes, same issue there - if I remember correctly (95% confident ;-)). I'll make some further tests next week.
Thorsten, if some of the motors spin slower than the others when you raise the throttle, then, maybe, you need to do motors/esc calibration. Yes, that is confirmed by checking MOT/RCOUT to see if motors are out of synch.
Willy,
thanks! Yes sure. That's what I did carefully.
Hi all,
I just found that using rc5:
Kind regards,
Thorsten
I searched for MOT. Was this renamed to RCOU?
Thorsten,
Yes it is. A number of people have asked that we update the log bitmask, especially for the pixhawk to include everything so I'll make that change for -rc6.
I was hoping to push out -rc6 this weekend but it's not quite ready. Hopefully around Tuesday it'll go out.
Randy,
Thanks! if I enable both IMU a RCOUT with Default in the Terminal the bitmask value is 1982.
@sixtimesseven,
I guess you're using a Px4 or Pixhawk? Sounds very much like the compass isn't working. The compass-external flag should automatically be set when it detects the external compass.
Would it be possible to merge this pull request in rc6?
https://github.com/diydrones/ardupilot/pull/1150
It is a very handy/simple gimbal for fpv.
180
181
182
183
184
of 262 Next
