ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Right before trying position hold I had trimmed my quad using set trim. Then re centered my trims on my radio. So i'm positive my trims were centered when I tried position hold.
      • Logging could be turned up so we can see more information.  I use Pos Hold all the time and it's works just fine.  I'm using it with EKF turned on.
        Turn up the logging and fly with just Pos Hold and post the log.  Something is causing the copter to pitch forward.
        • Could you be more specific by "turn up the logging" is there a faster log refresh or something I should adjust?
          • Your logging is set low.  Set it to Nearly-all so we have more data.
            Log Bit Mask
            • I recalibrated radio in mission planner yesterday per Randys advice. I took a flight today and position hold seemed to be working fine. So im assuming my issue was not having performed a radio calibration recently. I've attached my log files just for the hell of it.
              6.BIN
              https://storage.ning.com/topology/rest/1.0/file/get/3702874707?profile=original
            • Ok I have it set to nearly-all now so i'll make some flights this afternoon and post back.
  • I'm having some problems with position hold on 3.2 pixhawk. Everything is working well including loiter. But position hold just drifts and does not hold. My droidplanner confirms that position hold is engaged but the copter flies like its still in alt hold or stabilize. Any idea why? I've included my latest log file.
    1.BIN
    • ive seen the same with a couple local copters. didnt take logs though - curious what this could be - felt like it didnt have GPS, but it did.
      FlyHigh,
           It will almost certainly be because the roll and pitch sticks are not perfectly centered.  This can happen if the radio calibration hasn't been done regularly but it can also happen if you're using RCMAP.  There's a bug in AC3.2 in that it's not using the correct RCX_MIN and RCX_MAX parameters when RCMAP is used.  The workaround is to set the range (on the transmitter) of the roll, pitch, yaw and throttle channels to all be the same, and then re-do the radio calibration and ESC calibration.  Sorry for the troubles.
      • Hrm ok I know for sure that the range of my throttle is different, not sure on roll pitch yaw. But I changed my throttle minimum so that my failsafe would kick in if my radio cut out and the throttle went below my raised minimum. I will try making them all the same and recalibrating my radio. Thanks for the reply Randy.
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
RT @SmallpixelCar: Today’s race with @a1k0n at @diyrobocars We both decided jumping over the wall was the way to break the 11s lap time. Th…
Aug 14
