ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • That GPS looks pretty legit. How do you hook it up? I see it comes with UART, I2C and USB.
        with the 3DR compass, it uses I2C. Is the GPS port on the 3DR GPS/Compass combo UART?
        Is the accuracy on this really that much better? it says 2m.
        whitch is about what the ublox 6 gets.
        • Hi NullVoxPopuli,
          The hook-up is pretty easy, it can be accessed through the swift-nav website. I believe so, the gps is using UART serial communication.
          I believe you are mistaken brother, the piksi if used as an RTK gives 2-3cm accuracy. Right now it is being used a normal gps.
          -Rai Gohalwar
    • @ Raibrinder Gohalwar Did you try to connect the piksi (Serial port A) on pixhawk serial port 4/5 without the u-blox?
      Would be interesting to see difference in precision in between piksi and u-blox.
      I do have Piksi v2.3.1. What is the version you're trying?
      Henri
      • Hi Henri,
        I have tried many different configurations. The one that works the best right now is piksi(port a) to serial 4/5 and u-blox to gps port. when I turn off the u-blox and just use the piksi it doesnt recognize a gps. (Maybe the gps 2 in the parameters is not supposed to work yet. According to @ Mihai)
        I have 2.3.1 piksi. well two of them . I intend on using the rtk capabilities on the x8 quad.
        -Rai Gohalwar
        • @Raibrinder Gohalwar Thank you for answering. Did you try pixhawk serial port 3 (labelled GPS) to
          SwiFT Piksi UARTA alone? Perhaps the Pixhawk software just acknowledge Serial 3 as a valid GPS?
          Let me know..
          Cheers
          Henri
          • Hi Henri,
            I did try that and other configurations with that wiring setup. With just the piksi, the screen says: BAD GPS HEALTH. the other way I tried was to make both gps1 ang gps 2 =1(auto). That gave me a 3d fix. Thirdly, I tried setting gps1=8(swiftnav protocol) and gps2=2(u-blox) and I got gps=NO GPS
            Another interesting configuration I tried was gps=0(none) and gps2=2(u-blox) That also gave me NO GPS
            I have found that the loiter is not very stable and the logs are misbehaving when this wiring config is used.
            Pay a visit to my other discussion relating the piksi.
            https://groups.google.com/forum/#!topic/swiftnav-discuss/z34YTh-4Mvw
            -Rai Gohalwar
            I don't think the Piksi GPS driver is in master yet but I'm sure it's on it's way because I've seen the viceo of it working with an IRIS.
            • Hi Randy with Piksi .. will we get true cm level positioning? .. would this include altitude too or would we have use the onboard baro for altitude , one of main objectives for me is to fly around 500mm to 1000mm above a grape orchard without dropping and touching the vine rows and having a crash ..Like Kiwi fruit Orchards it is hard to use sonar , as the leafy canopy could not be reliable enough to bounce sonar off of , then you have the issue of at the end of the row you now have ground level , so maintaining a constant height above a leafy canopy on undulating ground is important to me .. ideas are welcome ..   cheers Reuben
              • I don't think you'll get nearly the precision you're looking for, especially since you need absolute positioning, not relative. If I were you I'd look at a kinect (I heard that there is a smaller version available). Good luck!
                M.
                Reuben,
                    I haven't flown with the Piksi myself so I really can't comment on the accuracy.  In arducopter we don't use the GPS altitude though so I wouldn't expect any change in alt-hold performance.  It's a slightly tricky problem you have there.
