ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
                @nickthecook,
                Yes, we're doing this actually using a bunch of #defines that include/exclude many features (but not all) depending upon the board.  For example the EKF and dual GPS are only on the Pixhawk.
              • Maybe another solution is to put altitude control separate something like super simple mode so that you can add altitude control on the modes that you want it on. It could also be put on a separate channel.
                stable, drift, sport,  simple, ss, with or without alt control
                even position hold with or without. Most will want it with since a position is a position but if you want to fly around in that mode but have your lateral space controlled when you release the stick. Maybe a better solution is to have altitude control auto enable in pos hold when you release the sticks but how it optional if you start moving around.
                Modes like Auto, RTL, Follow Me, Land, Guided would control altitude no matter what the alt switch setting is since it's mission would control altitude.
                • Would reducing the dead zone for altitude changes in poshold help with this issue?  I don't particularly notice a slowness in ascending and descending once I'm out of the dead zone. Maybe I'm missing something here.
                  • I think reducing the dead zone is going to help to some extent. I am going to load rc6 today and test it out. I am so used to flying in stabilize. So when I do try alt hold or hybrid/pos hold the delay can cause me issues. There is definitely still a speed difference in asc. and desc. rate. I currently have Pilot_velz set to 400 and I can still notice a difference in rates. However I also am not used to having to move the stick all the way up or all the way down to get the altitude change I am wanting.
                    Hopefully between the dead zone setting, trying pilot_velz at 500 and just trying to get a little more used to it I might get comfortable with it.
                  • "I don't particularly notice a slowness in ascending and descending once I'm out of the dead zone"
                    x2
            • Now is not possible because the "Position" mode was removed from the code, but i think a good idea would be introduce it again because PosHold with the manual throttle could be very useful.
              This would be awesome. I think it is the only thing missing from Hybrid mode.
  • Question:
    With Pixhawk, 3.2-rc5: To do auto-tune, best to do it with EKF on or off?
    Thank you in advance.
    Henri
    Don't try to replicate this, is dangerous if you don't know what you're doing.
    • MR60
      how long was the tested cable ?
      How will you attach your camera gimbal with this cable in the way ?
    • Ahhhh, finally someone came up with a practical way of preventing flyaways. Good job Marco. :)
