Hi all! After some pid tuning, but require further adjustment, today i made the first real flight with my "heavy ArduXOcto", i open this thread for sharing my experience if someone else wants build a similar "heavy configuration" using ArduPiloltMega 2560, IMU, GPS and Baro, etc.
I have previously tested more expensive systems like Mikrokopter and Wookong, and unfortunately i think there is still much hard work over the code for make this electronic flight like the competition, but considering the price i would say that goes too well.
I'm still quite satisfied, even though my copter in some aggressive maneuvers tend to wobble a lot, and in the Loiter mode some circles is inevitable because I believe that the management of the accelerometers correction is not optimized or inactive.
Over the baro range i've a good altitude precision, max 20/30 cm of excursion.
This is my hardware configuration:
- APM 2560
- OilPAN IMU
- Mediatek MT3329 GPS V1.6
- XL-MaxSonar MB1200 (with active filter and "thermal mods", 4 x 10 ohm resistor around the case)
- ESC HiModel Pro 30A, in high timing mode
- Two switching BEC 6V 5A (connected to electronics through two diodes 3A, the tension output is 5.33V)
- Motor TigerMotors MT2814 710 kv (mounted with 3° inclination for increase YAV control)
- Props APC 13x6.5 "E" (X8)
- Two-Way telemetry "Mikrokopter Wi232" (890 MHz)
- Six led strip connected to APM (pins AN8<->AN13 through ULN2003), thanks to u4eake for the code
- Homebuilt frame, mixed aluminum / vetronite (by AleBS, thanks dude! :P) + homebuilt hood
- Lipo 4s2p 5000 mhA 40c
- TX Futaba T12FG
- RX Futaba R6008HS
I'm uploading the video on my youtube channel, post them soon, for now I leave you some pictures.
I enclose the parameters used for the flight test in a soft wind, but there's one error, the real "Rate Pitch I" is set to "0".
Best...
Marco
NOW IN "X8 COAX" CONFIGURATION...
One of the first flight:
New video with "X8" frame and "ArduCopter V2.4"
When you try 2.1, let me know if the wobbles are still there.
Thanks!
Jason
Restiling: i've removed the vetronite motor support because there's a lot of vibration with this, motor is now mounted over the arms like Mikrokopter.
Stay tuned for the next video... :P
Flying awesome!
In your latest flight. Would you mind sharing your pids ?
Today tried to fly with 4 lipo 4s 5000 mhA (more payload) but one EPP prop is broken during an aggressive maneuvers.
I upload video on youtube now, stay tuned... :-)
I can't wait for APC props!!! :-/
Marco, you're interested in my mount? It's designed in AutoCAD, can you read those files? If not, I can show you a screen shot.
Basically it ends up about 5" wide, and about 6" long. The trick to making it narrow is I tucked the tilt and roll servo behind the camera, instead of on the sides. It's only designed to accomodate 25° of roll, there is no "halo" design for roll compensation, it's simply like a teeter-totter. That head is then designed to hang from a RobotZone servo power gearbox, like this for pan:
http://www.servocity.com/html/spg425a_standard_rotation.html
I just have to get the linkage design finalized. It's intended to use sheet aluminum which I will have waterjet cut. Then use some standard bearings. Should result in 360° of pan, 25° or roll and 90° (or maybe a little more) of tilt. It should fit any camera up to 4" wide. But the way I'm designing it I intend to have the camera tray with a full aluminum face lens shroud to protect the camera. Maybe even put a 37mm filter on the front of the lens shroud tube.
Nice work, I see you use the internal bec's for servos, have you done some measurment of noise to apm from this setup
I think all connection with the esc's is a bad deal.?
What camera did u use to take the pics of your apm and sonar???
New video after some pid tuning for increase precision in Loiter:
https://www.youtube.com/user/erarius?feature=mhee#p/a/u/0/E_igmgInUqs
please disregard below post! I forgot to read!
dude! how on earth did you make that hood?????
Very nice, could you tell me how to make the cap?
1
2
3
of 3 Next
