ArduIMU code version 1.7 problem in Labview
When I did the SVN update today with my arduIMU software, in labview when the arduIMU is connect, it no longer is printing out the pitch and the yaw and all the other data needed for the 3D cube to work properly. All it is outputting in the serial window in labview is   ver1.7 and tow0........Is this a bug in the new code? When I uploaded code version 1.6 for arduIMU, the labview readings are normal and how they are supposed to be. What is the problem?
  • Problem solved, I needed to set this line of code in the arduIMU code to 1
    #define PRINT_EULER 1 //Will print the Euler angles Roll, Pitch and Yaw
