ARDU-IMU test not working.
Test arduimu. Recommended programs to test the immu are not working. The SetupDemo IMUv113 runs without errors but does not present the data. The SerialServerVi not work (file "WSC32.DLL" not found).
The software utilities ArduIMU Demo1 also run without showing values. What is happening can.? I remember I had problems in using ARDUINO under Windows. It took the board through the upload LINUX UBUNTU. There is a soft test for Linux?
    Have you sucessfully loaded the ArduIMU code on to the board?
    The test utility works fine, in either binary or ascii mode. [#define PRINT_BINARY 1 //Will print binary message and suppress ASCII messages (above)]
    What output do you see from the Arduini IDE serial monitor (38400 baud)? You should see something.
