Posted by Avalerion on September 9, 2010 at 8:20am
I loaded version 1.7 of the ArduIMU code on a v2 board. When testing in the ArduIMU Test 1.1.17 program, I can see GPS but no ArduIMU values. Am I missing something? Do I need to hook it up to the ArduPilot Shield?
You need to turn on the fields you want to see (so switch the 0s to 1s for the fields you want):
#define PRINT_DCM 0 //Will print the whole direction cosine matrix
#define PRINT_ANALOGS 0 //Will print the analog raw data
#define PRINT_EULER 0 //Will print the Euler angles Roll, Pitch and Yaw
#define PRINT_GPS 1 //Will print GPS data
This is explained in the manual.
