  • I'm having the exact same problem. After power on I get a solid green, solid yellow, and blinking red led.
    After that I can't arm the motors, presumably because it is not in stable mode.
    Did you figure out a solution?
  • i have the exact same issue when i've uploaded the sketch and adjusted the perameters to use the AruIMU with my DOSD V2+ ... so i'm in the same boat.
    Brian
