Arduino software installation
Any persone can help me with the instructions to assembly all hardware and to installation of arduino software. Because I live in Colombia and is difcult buy any component in event of mistake with assembly installation proccess.Excuseme for me bad english.
  • Hello Chris:
    Really I check in the manual but not found the Pin or conector to connect the positive cable and ground cable of 5 volt battery pack. I solder the Jumper in the board to inform the system the use of external battery, but I´m very careful with the correct power conection because don´t want made mistake with this Main board because is very dificult buy newly this unit. Excuseme for me children questions, but is very satisfactory for me, finish this project without error for time and money dificults. Please send me a diagram or picture for the correct cable power supply installation.
  • Thankyou for your response and attention to me e-mail, because I think that any person response my ignorant question.
    I have ATMEGA 328 Processor. I download the arduino 17 from intenet but this version not install in my computer, I try with the arduino 16 and this run correcctly, I´dont know if the arduino 16 work correctly with arduopilot version 2.3.
    I have one additional question if you can help me, the question is: How I can power the board with external battery, because I´dont know what PIN or Conector need the inputexternal power volatge and ground, to power the main board with external power supply (Battery). Exist a special pin to connect the external power and ground ? Or is possible connect the conventional FUTABA receiver and only with the conections from the servo without speed control (For Gas engines) the main board is electrical power.
    Thankyou very much and excuseme any inconvenience with my english.
    Best Regards,
    Gustavo Otalvaro
  • Do you need help getting the Arduino Bootloader on a raw ATMEGA168/368 ? I can help in that area, as I just spent all of last weekend figuring out how to do it from scratch.
    -Steve
