Arduopilot tuning for Rookis,
Arduopilot tuning for Rookis,I now have the arduopilot into my Maja system installed and first testsmadeNow I still have problems :1 . If the aircraft is in auto mode, if it turns, it makes the turn too long!2 . the aircraft is flying too slowly3 . The elevator is going up when i switch into auto modecan you tell me what parameters I must cangeThanks for your helpPeterVideohttps://www.youtube.com/user/Koppik2#p/a/u/1/1Z9QpyTSoA4
  • Hello,
    Yes ! it turns past the desired heading
    i will try changing AIRSPEED CENTRAL
    Yes ! when i switch from Manuell to RTL and waypoint the elevator move up
    The catapult is selfmade
    Peter
    @Peter - your video doesn't help with answering your questions. We need more information.
    1 - What do you mean "it makes the turns to long"? Do you mean it turns past the desired heading, or the turn radius is too large, or something else?
    2 - Try changing AIRSPEED_CENTRAL and throttle_absolute
    3 - When you switch into auto mode do you mean RTL mode or waypoint mode?
  • Admin
    Hi Peter,
    The catapult angled little upwards will help. For some reason the power seems missing both in catapult and the model
  • Admin
    Peter,
    Did you build the catapult yourself or is it a commerical catapult?
    TCIII
