I used to fly Ardupilot with 2.46 and it works without any problems and very happy about its performance but recently I have been upgrading from 2.46 into 2.502 or 2.503 but never work it out. It seems that CH1 and CH2 serve plus can not be detected. I use Ardupilot_25_Radio_test test it and finf out all CH1 and CH2 plus all under 1000. I move to CH1 rudder left @857, Center @850, Right @853 but while I move CH1 to left @857, my CH2 also move from 959 to 1028.....that is a very strange movement as I did not move CH2. When I only move CH2 up, center, down, it did not show any signs of moving and stay @959.
There are more problems when I load 2.5.03 such as GPS blue LED false luck all the time, CH1 serve steady twich @ FLY_BY_WIRE ; FLY_BY_WIRE mode has no response from radio movement. Switch to FLY_BY_WIRE and STABILIZE mode sometimes cause ardupilot freeze. I am thinking that it looks like my Radio is not in right setting.
I am using JR PCM9X and JR SPCM receiver R900S, ardupilot 328, version 1 shield, em406, XYZ sensor. Soldered both the jump wires on the bottom of the ardupilot.
My Ardupilot_25_Radio_test Head file setting as following:
#define SHIELD_VERSION 0
#define AIRSPEED_SENSOR 1
#define GPS_PROTOCOL 1 // 0 = NMEA, 1=SIRF, 2=uBlox, 3 = IMU Choose protocol
#define MIXING_MODE 0 //Servo mixing mode 0 = Normal, 1 = V-tail
#define ENABLE_Z_SENSOR 1
#define XY_SENSOR_LOCATION 0
#define SET_RADIO_LIMITS 0
#define SET_RADIO_TRIMS 1
#define CH1_MIN 1220 // (Microseconds) Range of Ailerons/ Rudder
#define CH1_MAX 2043 // (Microseconds)
#define CH2_MIN 1041 // (Microseconds) Range of Elevator
#define CH2_MAX 1765 // (Microseconds)
#define CH1_TRIM 1500 // (Microseconds) This is the resting position for your sticks - 1500 = no trim
#define CH2_TRIM 1500 // (Microseconds) Trims are normally set automatically in setup.
#define CH3_TRIM 1015 // (Microseconds) Trims are normally set automatically in setup.
#define THROTTLE_IN 1 // (boolean) Disables throttle when set to 0
#define THROTTLE_OUT 1 // 1 = throttle, 0 = no throttle at all! (good for saving fingers on the bench.)
#define FAILSAFE_PWM 950
Tags:
45 members
1472 members
282 members
470 members
57 members
Powered by
